Does blowing a fuse cause any damage?
  • 4
some dude
I myself was once president of Algeria
I have a 60 amp fuse on my JP23. The amp is wired to 1 ohm, so it is capable of putting out 2500ish watts (on a dyno).
If I had it up loud and the fuse blew, would that be able to cause any damage the the amp? The subs?
I'm think about the violent collapse in electricity supply.
It shouldn't, it lost all power. It's not like you were trying to play em as loud as you can while underpowered. It's no different then turning off the power button on your head unit.
Not sure why you have that fuse on there though. That fuse is for the wire, so unless you have 8awg wire on that, and your amp doesn't have its own fuse, it should be sized between the amps fuse and the wire's capability.
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
369
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
976
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
some dude
some dude
Virginia
audiobaun
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
