Does my electical system NEED upgrading?
  • 5
MellowHype
Running 2 alpine type R's on a kicker ex1000.1. 1000 watts @ 1 ohm
Also a set of alpine type R components at 100 watts @ 4 ohm
I just checked my voltages, when the car is running with no lights/heaters/soundsystem i got a reading of 14.09v
When i bumped my sound system up to max volume playing one of the loudest songs i got a lowest reading of 13.20v.
Is this a bad drop? maybe something a big 3 could fix?
Thanks for any help
Big 3 is always recommended. But 13.2 at full tilt on a stock electrical isn't bad. Was that at idle?
Yeah that was at idle, forgot to mention that again was no lights/heaters or anything just the system
Ill look into some 1/0 gauge the shits just so expensive over here (UK) and terminals are a lot too
You are good like that. Just try to make sure you have good connections, grounds, re check your gains and if possible do the big 3.
i measured ground resistance when off and got .02 ohm so im guessing thats decent?
Yeah im going to look into some 0 awg but its going to have to be CCA not OFC as i just cant afford OFC atm. Ill try go with Knu KCA
i measured ground resistance when off and got .02 ohm so im guessing thats decent?Yeah im going to look into some 0 awg but its going to have to be CCA not OFC as i just cant afford OFC atm. Ill try go with Knu KCA
knu is a very good wire, that's what I use. you will be good with cca, but if you have future plans in upgrading your system, it's better to save a little more $ and go with the ofc from the beginning and at the end you will save $ .
Will go with CCA then, the only upgrade ill be seeing is a new 2000 rms amp but thats gonna be a while
Thanks
from what i've seen, its like $1 per foot if you order it off of amazon. and since its for the big three, you don't need a whole lot
50 feet just for a big three upgrade??
thats not including terminals, i think they go for about 16 dollars a pair roughly
dem UK electronics prices
Looking at US prices is depressing lol i could have bought 2 sundown sa -12's for near enough the price i paid for 1 type R
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
331
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
980
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
947
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
MellowHype
MellowHype
Uk, London
OzNath
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
