Don (6spdcoupe)...look what I FINALLY got today!!!!
I have a f150 '05 and i'm thinking of the powerline cs. Do you think the stock grills are too restrictive. Have you tried them with the grills on and off. how are your clerences between the grill and speaker and speaker and window?
Alot of trimming (door panel plastic), you're gonna need at least a 1.5" mdf ring/adapter and you will not be able to use the grilles if you want to put your door panel grille back on.
bry, you ****... how dare you disband the f150 forums
styx...**** my nuts!!!! btw, your mirrors are too small and are fugly too!!!!!
//content.invisioncic.com/y282845/emoticons/moon.gif.9d317aec3339ffe7fde0638df52c628a.gif
I think you misunderstood the question. I was talking about the stock f150 trim grilles being too restrictive. I thought of a solution were I can drill out the non functiong holes with small drill bit then sand some material off the back side where the larger speaker area would be. But I would try and see if there is an audiable difference with the grilles on and off first. good luck with the new truck!
1 2 3 4 I declare a thumb war, 5 6 7 8 with this hand I mahsturbate.
5
964
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
These would be my options for a single DVC4 sub wired to 2 ohms.If you decide to run another sub later of the same as a pair for a 1 ohm load, I...
Coulda already had his answers (4) My interior dome lights are dimming with bass | DiyMobileAudio.com Car Stereo Forum
20
3K
brypink
brypink
Temecula, CA
fair warning
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
