Double Posting
I honestly don't think this problem is something that can be solved by Goob. I think it would require completely changing the host, which would take a pretty long time. I don't think the double posts are really that much of a problem, although the server does seem to screw up quite a bit. You might be able to complain or do something formal to get your prices cut at least.
i have been doing it alot tonight... go look at the jbl crown amp thread 3/4 of it is double post
For me, every site I've been to has been slow. Not sure if its a widespread problem somewhere or not.
If you click reply 1 time and let it do its thing, it shouldn't be double posting now though. It might take a few seconds for it to do it.
I'm telling you, the problem doesn't have to do with anything on your side. I've double posted several times, and I know not to click more than once. Every time it's happened to me, it's happened because of the server. I click reply, it tries to make a connection for almost a minute, then when it has loaded, there have been two posts made, or more. If it was because of a browser or code, it would happen all the time for whoever has double posts.
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
7
I’m at 3 yrs on my Tucson alternator. W the electrical challenges i faced it’s been worked hard. Thankfully those challenges have been overcome...
99
10K
Suicide Bobb
SPLC Fails
Suicide Bobb
Camas, Washington
administrator
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
