COMPLETED dual alternator bracket 05 Explorer 4.0L
  • 4
lyonww
s the title states, I am looking to buy a dual alternator bracket for my 2005 Ford Explorer 4.0L SOHC. I have searched high and low and have found nothing. If anyone can point me in the right direction that would be great.
IF you have a 4G alternator be prepared to cough up some money for an Alternator. Those are a PITA to build up I got lucky with mine since a friend's family owned a alternator/starter repair shop but those 4G alternators people do NOT want to build them and I can not blame them and if they do they are very expensive & do NOT go cheap like one of those cheapo eBay alternators either. Find a place that will make one, IIRC Singer will but Mechman will not at least they said no when I contacted them a few months ago as I wanted to upgrade from a 250 amp to a 320 amp or higher.
Also Pop I have that link saved as well. That is about the only place that has a Dual Bracket setup for that 4.0 for some odd reason.
157
465
947
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
892
lyonww
lyonww
Georgia
Boominburban
    Jun 1, 2024
    May 31, 2024
