Southwest Region Dual in the desert/ HOBBS NM/ May 14
AZ,CA,NM,NV,UT
  • 2
152
860
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
844
952
speedyjuarez
Premium Member
Premium Member
speedyjuarez
Live in Hobbs, NM. From Ft Worth, TX
BEEKAY
    May 19, 2024
    May 19, 2024
