DVC to two channel amp
I'm not an expert, but short answer... Yes but you'll have to match gains and all their settings so you're not causing any issues with each VC seeing a different sigal..
but if you're amp is not 2 ohm stable I think (again I could be wrong) once you wire it to the sub it would be seeing that 2 ohm load... Might help to mention the sub(s) and amp so we see what you're up against!
No. A Dual 1 ohm subwoofer will only wire to 0.5 or 2 ohms. 4 dual 4 ohm subwoofer will wire to 1 ohm or 4 ohms. Again it's still a monoblock...
13
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
504
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
Darkstrike120
Darkstrike120
United States
Darkstrike120
maylar
    Jun 2, 2024
    Jun 1, 2024
