Eclipse / TC Sounds LMS 10" SW8000
ciaonzo
TheContinental
11,703
76
WI
10" Eclipse SW8000 BNIB
This is BNIB but I did remove the logo as I always do with Eclipse drivers. TC9 motor with a big copper shorting ring, and a very lightweight aluminum LMS coil. Sealed enclosures ranging from 1.5-2.25 cu.ft will be best. Thermal is pretty great on these, I watched a video of one seeing wall power for minutes on end. This allows for awesome dynamic capabilities for which I can attest to. I've been thoroughly enjoying one on a USAcoustics 2300F for the past couple years. Makes over 1k @ 4 ohm. This driver will challenge your amplifier so make sure to pair it up with one that is happy to run at 2 ohm all day. It would also be a shame to use this driver with an amplifier that has a subsonic filter. This thing digs down into the teens without any issue. 15-16Hz is insane in my vehicle. Even a SSF that is centered @ 10Hz is aggressively filtering out 19Hz and below.
These are older pics below but I will put some fresh ones up if you prefer. Condition is exactly the same (only selling the driver on the right with the plain cone).
$225 shipped, CONUS.
CONUS only, please.
I ran it for quite awhile and then traded it to a buddy of mine who is running it in his home theater currently on 1k. I'm actually looking to get it back to put in the road trip car. Haha. How would this single 10 do in 1.8 cubes sealed on a mmats d2100.2 compared to the w15s infinite baffle?
I can tell you it sounds great in 1.8 but I don't have any experience with the JBL to make a comparison.
How tall is the sub? Wondering if i could make it fit behind the seats of a single cab Silverado.
Roughly 8.25" or so. Might be a struggle for you once you factor in excursion.
Hmm yea a center console with it would probably be best... I was going to do 2 10" re xxx in a center console but one of the motors is shifted pretty bad and will be about $100 to fix from Scott at FI... Price still $225?
Yep, $225 shipped.
Hey man I just picked up two of these 12s on offer up for an absolute steal. Are you aware of where I can get the specs on them?
Heyyyyyyyy Cooooooool!!!!!!
You try Google?
lulz
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
924
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
