Eclipse TI Pro 18 Subwoofer
mfenske
aemracerex =POS
1 Eclipse SW9182 18" Subwoofer
Item is used and in good working condition. I picked this up locally. I LOVE this sub but it's just too big for my application. The magnet has a few scratches on it because it's like a decade old. There's a little what looks to be spray foam on the basket from the previous owner. All the coils ohm out between 1.5 and 1.9 ohms. Surround is in good shape. From what I understand this is essentially a TC 5200 clone which means it has a 4" voicecoil and monster motor. I've bought and sold a handful of items on here and LOTS of items with positive feedback on DIYMA.com
I'd need to get 430 shipped to the lower 48 states via paypal
I'll cover the shipping but will likely send it in two boxes (USPS flat rate on motor and probably UPS ground on the top assembly) because it's huge and heavy.
I guess I don't understand how to measure, should that be done outside the enclosure?
Not exactly a gauge for it. Just trying to determine if they'll be okay with the current cone on a 10k burp. Thinking about switching my sub which is incredibly stiff and built for big power burps. The 4hp stock was good, but only if it hasn't been playing 5k for 10 years.
I look at this woofer as more of a daily listener than a burp monster. I know the previous owner had about 2,000 on it. I've been running less than 200 (need to get a monoblock).
Definitely good for daily, but it can certainly do both.
Let me rephrase... Do they still feel stiff?
AFAIK these should have been pretty soft when they were new.
You'd be far better off building for burps on that motor and saving the Eclipse top for music. Suspension will not be stiff, Ti cone isn't going to be as good as pulp, and those embedded tinsels are problematic much over 3KW.
Ah thank you for the info. Maybe I'll stick with what I've got then. I know it sounds ridiculous, but I don't play daily. I'd be wasting a lot of money on this cone just to build a new top for it. This would be better suited for someone who will use the whole thing.
Makes sense,thanks!
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
7
I have a couple 3000s and 5000s and cant remember the other two right off hand, but these will not work with your unit that I can think of by...
4
880
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
mfenske
aemracerex =POS
mfenske
Portland, Oregon
mfenske
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
