Electrical for M4a
  • 4
adulbrich
Olive oil un-virginer
14,433
123
Ames, Iowa
Hey, like the title states, I'm wondering what I need to run an M4a. It will be wired at 1 ohm for daily. I will also be running an Ampere 125.4 for an active front stage.
Going by the 55 ah per 2k rms, I'll need about 200 ah of batteries.
I have a 320 amp Singer hairpin alternator. Would that and 3 Sam's club Duracell batteries be enough?
What voltage drop is acceptable, and what should I not let it drop below? Gains will be set wit a 0db test tone and o-scope.
All music I play is from itunes, so I'm not worried about signal quality.
Thanks!
The m4a can draw over 700a. So minutes about 220 from your alt leaves 480a needed. 4 g31 plus your bay under the hood.
Does the brand of group 31 matter? The Duracells are half the price of an XS D3100. I may try and fit another alternator
Also, same Big Ben from caraudioclassifieds?
You'll get better performance from a better battery. XS isn't the brand to judge all others by. Yea they're good, but you can find as good for less. Northstar makes a beast, odyssey pc2150, JuiceBox banana is equal to those 3, another great alternative is the JuiceBox black cherry that can be had for ~$200 each. Why cheap out on the most important part of the build? Short change your electrical and your amps will pay the price. Save a few bucks on wire. Don't waste it on XS, Knu, it Sky High Car audio cable. You can get high quality, pure copper welding cable for less than half the cost of the big name brands. $2ft for 2/0 welding cable, or $5+ per door for car audio cable.
---------- Post added at 07:49 AM ---------- Previous post was at 07:49 AM ----------
Yes, same Ben
I was looking about Northstar, but didn't have experience with them. I'm hesitant to buy a juicebox. Are they good quality for the money? I may do some of the black cherries or bananas if they are. Someone on here runs the Duracells and says they are solid
I run black Cherries in 2 setups. They hold a higher resting voltage than my xs did. The difference in the black cherry and banana is capacitance. Basically it's the difference that an xs d3100 is to the xp3000. Same size and voltage but the d3100 and banana will or perform the black cherry and xp3000 by a small margin
So what voltage drop is too bad? How hard can I push it? I keep my Banda in the 13's, but I know the M4a is over-built. How low can I take it? Are 12's ok?
The m4a is rated at 11.9v so anything above or a couple tenths should be fine. I personally dont like falling below my batteries resting voltage just to be safe.
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
Update: The burning smell is slowly going away at middle volumes. To the point where it only comes on at middle volumes. I adjusted the sub master...
17
4K
adulbrich
adulbrich
Ames, Iowa
adulbrich
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
