T Topnotch5 CarAudio.com Newbie 6 2 Ohio Jul 29, 2022 #1 Best secondary battery for a taramps smart 3 Click to read more...
audiobaun 5,000+ posts CarAudio.com Veteran 15,972 2,149 USA Jul 30, 2022 #2 Id look at a Duralast Gold AGM 1000CCA, If you have the room , Id add another under the hood also. Or look at the Orileys Super Start AGM batteries. Both have done great for me for the $ 1
audiobaun 5,000+ posts CarAudio.com Veteran 15,972 2,149 USA Jul 30, 2022 #3 The Super Start AGM group 34/78 Dual post is nice to have I use in my 98 xcab and easy to add on to. If you can get a Dual post . be the way to go 1
audiobaun 5,000+ posts CarAudio.com Veteran 15,972 2,149 USA Jul 30, 2022 #4 Stay away from the Optimus Red Tops and Yellow Tops.. Complete Garbage!! 1
audiobaun 5,000+ posts CarAudio.com Veteran 15,972 2,149 USA Jul 30, 2022 #5 Duracell AGM batteries are very good also, and If you have a Sams card, you may be able to find a good buy on those as well or at a Costcos
audiobaun 5,000+ posts CarAudio.com Veteran 15,972 2,149 USA Jul 30, 2022 #6 I recommend Charging an AGM to full potential before installing with an AGM charger like a Noco 10. One best little car battery chargers I use to date https://www.amazon.com/dp/B07W3QT226/?tag=caraudiocom-20 1
