Extreme Audio
  • 5
Trey803
GAMECOCKS
5,949
SC
If you ever get the chance to go here please dont. There prices are out the roof installation takes up to two days and they screwed a ground wire down with a metal screw into the bottom of my freinds truck.//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
No comment on the time frame for installs but I don't guess I see the problem with what I have bolded. If there wasn't a sufficient ground point already available how do you recommend they should have proceeded?
Shoot- my main ground is welded to the spot it is attached to!
how else would they do it?//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
so....they grounded with a screw to the cars body.....
and that's a bad thing?
then you wouldn't like our shop (Circuit City in Augusta) cause we scrape the metal bare and THEN screw it down with a screw...lol
i think what this man is saying is they took a screw and just screwed into his floor when there were many places to ground it without creating a random ass hole in his truck.
I would assume it is the radio's built in eq curves that are meant to protect the OEM speakers. You will need a DSP with signal leveler. That...
949
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
142
Ill check it out. I was actually on the site last week. Thanks!
281
Trey803
GAMECOCKS
Trey803
SC
budahbuddy803
SlugButter
    May 4, 2024
slater
    May 2, 2024
