Fixing Broken Car Amps
the red one looks like the poweraqustick demon 6000 i have the same amp but i blew mine the guy an the shop said i blew it because it wasnt enough poer getting to the amp is this true the protection light stays on i even checked all my leads still doesnt work
Ive been fixing broken car amps for 10+ years. The price i charge is 25.00 plus parts and shipping to fix amps. I go through the entire amp to see whats wrong with it and then contact you with the total. My turn around time right now is 2-3 business days to complete . All amps i repair come with a 90 warranty on parts and labor. I only use brand new parts and never use old parts when repairing amps. For example if you have 1 or 2 blown outputs or power supply fets that are bad i replace them all so the amp is reliable.
So if you have any amps that you are inrested in getting fixed please send me a message at mike49504@hotmail.com .
Thanks for looking
I'm in the middle of diagnosing my Sega Genesis v2. Won't pass the licence screen, ugh! Cart pins show continuity and following the pins to the board for connection was an hour+. I kept this ***** in good working order in the 90s. Caps looks almost boring. Flat as a rail. Next week I'll take some voltage readings. Much easier than mosfets and, well. I'll just replace a $220 amp if it's not my fault.
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
502
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
894
mike49504
mike49504
Grand Rapids MI
fixinit
    May 24, 2024
    May 23, 2024
