FS : 2 SKAR VVX 12 D2's
my_stealth21
Tulsa,OK
2 SKAR VVX 12 D2's
These 2 SKAR AUDIO VVX 12's are in excellent condition they only have a total of about 2 hours of play time on them. One of the subs has a very small scrape on the cone that is barely visible and thats it. 10/10 mechanically. These subs perform very well I had them in 4 cu ft net @ 30 hz and they sounded great and got pretty brutal ! Just wanting to try something else.
290 shipped for the pair. Possible trades for TC/Audiopulse Drivers. These subs will ship in the original packaging.
UPS ground or your choice.
I have them on a BC2000 at .5 ohm in 4cu ft net @ 30hz and they take it no problem so I would say 900 to 1000 rms per sub is fine
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
404
840
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
my_stealth21
my_stealth21
Tulsa,OK
my_stealth21
    May 31, 2024
    May 24, 2024
