FS: JBL GTX 8" subs w/ box
  • 4
93 saturn sl2
Michigan
Two JBL 8" GTX subwoofers with or without box
one sub is in great shape and has only been installed for a month or so. The other sub works, but the surround has separated from the basket about 1/4 of the way around. Still works though, but makes a rattle due to the surround separating. It did not make the noise before.
Single 4 ohm. Box is optional. Its a prefab, nothing fancy.
$90 shipped for both subs w/ no box. $160 shipped with box.
400wrms. I had the spec sheet saved to my computer, but cant find it atm. I was giving them 125 a piece.
It runs from 6 o'clock to 9'o clock, if the sub was a clock.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
93 saturn sl2
93 saturn sl2
Michigan
93 saturn sl2
    Jun 1, 2024
    May 31, 2024
