SOLD FS: Power Acoustik 4ch 1200watt Amp
thakid22
This is a 1200 watt, 4 channel amp. Great Bass. Terrific volume, Clarity is nice too.
It is used, but in excellent condition. Here are some stats from the manufacturer:
# 1200W Max, Power Series 4-Channel Amplifier
# RMS Power Output:
* 4 ohms: 100 watts x 4 channels
* 2 ohms: 125 watts x 4 channels
* Bridged, 4 ohms: 250 watts x 2 channels
# PWM MOSFET power supply
# High or low level inputs with floating ground
# Variable low-pass crossover (40-120 Hz)
# Variable high-pass crossover (150-1,500 Hz)
# Variable 18 dB bass boost at 40 Hz
# Tri-Mode capable
# 3-Way protection circuit
# Platinum-plated RCA terminals
# RCA preamp outputs
# Frequency Response: 10 Hz - 30,000 Hz
# Dimensions: 13"L x 11-3/10"W x 2"H
$60 Paypal. I am paypal verified. You can check here:
https://www.paypal.com/us/verified/pal=HondaTrendz%40yahoo%2ecom
No charge for shipping.
RMS Power at 2 Ohms 250 W x 4
RMS Power at 4 Ohms 100 W x 4
I have a question about the power. Given that in the automotive world you can make about 100w with 10 amps of power on 12 volts @ 75% efficiency, how does it do 1000w RMS with a 50a worth of fusing? Can you guarantee this power output if i buy the amp?
don't bust his balls, he just got the numbers wrong, it is rated at 125x4 @ 2ohms
i got the "sub" amp from this line. rated at 280x2 at 2 and get to about 250 before any audible difference. run it on a pair of infinity 10's in a .75 sealed box each sub and it sounds great. not the best amps but for 60 bucks that thing will put out 80watts at 2 ohm at least. if not 100.
This might be a repost... but I don't think it posted the first time... I think it was being flagged for moderator review, because I included a link. This is a try with no link. PM me if you need the link I was trying to give.
BradButlerNC,
I am relatively new to aftermarket car audio. That being so I can't tell (nor guarantee) if this amp under or over performs according to it's specs. Was there something fishy with the specs? I copy and pasted them from a vendor website. Let me locate some more accurate info:
Sonic electronics had these specs and more, listed. So go buy and check it out.
THere are a couple of reviews too.
# RMS Power Output:
# Tri-Mode capable
Being so new to car audio, I did lot's of reading/research before I bought it. Never once did I come across a comment about the amp not performing up to par.
In fact the recurring sentiment was that this was a strong amp, that far outperformed it's price. I don't have much to compare it to, but this amp provided more than enough power and clarity to power my Blaupunkt speakers. 2tweets, 2 6.5's, and 2 6x9. 6 total. Even with the gain down low, the amp produced killer sound. I had the sensation that I had way more amp than speaker.
Volume, Bass, Clarity and Accuracy were not a problem.
Check some reviews of this model out, and you'll find what I did. Very few (if any) concerns about it's power, and lot's of satisfied users.
If you need more info from me let me know. I look forward to doing business with you.
Cable plugged in all the way? I know I had one and it didnt plug in fully unless you jammed it in pretty hard. Also, I suggest DS18 Bass Knob with...
I would consider a different brand. Whats your budget?
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
540
thakid22
thakid22
Little Rock, Ar
thakid22
