SOLD FS: SI Mag15, DLS A5 (LOCAL ONLY- OC,CA)
  • 7
JAZN
SoCAL
I'm going broke so sadly I need to sell off parts of my system. For now, I'm only selling LOCALLY in ORANGE COUNTY, CALIFORNIA.
Stereo Integrity Magnum D2 15" $275
Cone/surround are practically flawless, the bottom plate has a small discoloration on it that came that way. Mechanically 10/10
http://www.stereointegrity.com/Magnum12.html
DLS A5 $350
A couple minor nicks near a few of the mounting holes, barely noticeable.
Most of the small specks in the pix are dust particles, I didn't realize the dust would show up so much :p
I did open up the amp to make sure it's not a fake.
Includes bass remote but I don't have the cable for it. It's uses a simple phoneline though, so you shouldn't have a problem buying one.
Number of channels 3
Amplifier class AB
Damping factor > 200
Mono bridge mode 4 ohm N/A
S/N ratio, A-weighted >100 dB
Typical power in 4 ohm 2 x 85 W
Typical power in 2 ohm 2 x 100 W
Mono sub channel 4 ohm 300 W
Mono sub channel 2 ohm 500 W
Input impedance, high level N/A
Mono sub channel output in 1 ohm 780 W
http://www.dls.se/en/car/prod.html?produkt=en_10
Amp sold. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
JAZN
JAZN
SoCAL
JAZN
    Jun 1, 2024
    May 31, 2024
