FS: Soundsplinter RL-P 12" Dual 4 Ohm Subwooder
nbro3232
(1) SoundSplinter RL-P 12" Dual 4 Ohm Voice Coils 12" Subwoofer
This sub was purchased on this forum a few years ago from PepsiFiend69.
There is a small tear in the surround that was there when I purchased it. It was repaired using RTV by PepsiFiend69 and has never been an issue in the years that I have used it. It has performed flawlessly with 750 Watts going to it.
I just got bucket seats in my truck and built a center console box for a 10", therefore I have no use for this sub anymore.
Specs from SoundSplinter's website:
Dual 4 Ohm
Qts: 0.219
Qes: 0.242
Qms: 2.266
Fs: 18.856 Hz
Re: 6.26 Ohm
Ls: 7.382 mH
Rp: 14.68
Vas: 142.7 L
Mms: 168.8 g
Cms: 421.9 u
Bl: 22.74 T*m
SPL: 87.79 dB
Sd: 0.0471 m^2
Xmax: 24.2 mm
Measurements
Mounting Depth: 17.5 cm
Total Depth: 18.5 cm
Outside Diameter: 31.8 cm
Weight: 35 lbs
Magnet Width: 18.8 cm
Mounting Cutout: 28 cm
Displacement: 0.15 cu ft
[ SoundSplinter Subwoofers - RL-p 12" Subwoofer Information ]
$125
Shipping shall be paid by the buyer. Item is coming from zip 32304 and will weigh 35-40lbs. Shipping should be in the $20-$30 range.
Wow, a great sub for a great price! What box did you have it in?
I had it in a sealed box around 1cuft which was really too small for this sub. Thats another reason why I am getting rid of it.
---------- Post added at 10:06 AM ---------- Previous post was at 10:05 AM ----------
meet up ??? ill take this for sure.
Send me a pm and we can discuss.
206
518
958
nbro3232
nbro3232
Tallahassee, FL
briankeith
