FS: Soundsplinter RL-P 12" Dual 4 Ohm Subwooder
nbro3232
(1) SoundSplinter RL-P 12" Dual 4 Ohm Voice Coils 12" Subwoofer
This sub was purchased on this forum a few years ago from PepsiFiend69.
There is a small tear in the surround that was there when I purchased it. It was repaired using RTV by PepsiFiend69 and has never been an issue in the years that I have used it. It has performed flawlessly with 750 Watts going to it.
I just got bucket seats in my truck and built a center console box for a 10", therefore I have no use for this sub anymore.
Specs from SoundSplinter's website:
Dual 4 Ohm
Qts: 0.219
Qes: 0.242
Qms: 2.266
Fs: 18.856 Hz
Re: 6.26 Ohm
Ls: 7.382 mH
Rp: 14.68
Vas: 142.7 L
Mms: 168.8 g
Cms: 421.9 u
Bl: 22.74 T*m
SPL: 87.79 dB
Sd: 0.0471 m^2
Xmax: 24.2 mm
Measurements
Mounting Depth: 17.5 cm
Total Depth: 18.5 cm
Outside Diameter: 31.8 cm
Weight: 35 lbs
Magnet Width: 18.8 cm
Mounting Cutout: 28 cm
Displacement: 0.15 cu ft
[ SoundSplinter Subwoofers - RL-p 12" Subwoofer Information ]
$125
Shipping shall be paid by the buyer. Item is coming from zip 32304 and will weigh 35-40lbs. Shipping should be in the $20-$30 range.
Wow, a great sub for a great price! What box did you have it in?
I had it in a sealed box around 1cuft which was really too small for this sub. Thats another reason why I am getting rid of it.
---------- Post added at 10:06 AM ---------- Previous post was at 10:05 AM ----------
meet up ??? ill take this for sure.
Send me a pm and we can discuss.
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
229
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
888
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
854
nbro3232
nbro3232
Tallahassee, FL
briankeith
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
