Fu 750's just went up $20..
I'm happy for you old man! I think your really going to enjoy it! My fu300 10s came in today. I have no plans for them as of right now but someday I'll do something crazy with them lol and they are definitely 28lbs each I remember you doubting it before //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
https://imgur.com/gallery/dhWUR
****. I think it's still a good deal. I was gonna get one as a backup. Even the 1250 is a good deal
Sent from my John Kuthe can eat a **** and **** off back to nambla with the rest of the kid touching perverts
My buddy just got his 1250 18s. Im excited to see how they do. Will be on a Taramps 8k of course //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Yea those 1250s are interesting.
yeah good to know.. wish i woulda won those i'd be designing a dual 10 box lol..
Next tax season I plan on upgrading to a 1250 15!
my friend loves his., thinking of making his own box (after i draw it up 3.5cf maybe) and running 2k amp to it., needs more than his cab 1600
---------- Post added at 08:53 PM ---------- Previous post was at 08:52 PM ----------
the cones are beautiful i'd show u pics but my friend takes horrible pictures..
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
2 of them?
ayyyyy
good for you grandpa, stepping up in the bass world.
Is the amp next?
no man i was supposed to be done months ago lol.. this sub and box maybe last things i ever get to buy that i want.. everything else will be medical bills and paying peeps to cut trees and replacing our 15 yr old appliances..
Took you all of 2 minutes to change your avatar. Did you at least get a Dual 2 ohm so we no longer have to see you quote your amps 2 ohm dyno number //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i know right.... no.. i tried man but my buddy looked at motor and even he said that would be a pain in the a*s to do big 3 on (and he basically did 0ga big 6 on his, 2 batts underhood) i figured out what i'd have to do, 1 problem is easy just ground to alt instead of going over supercharger belt to motor but my terminals are weird and i ran #'s i would get more power at 1 ohm than i thought since after rise sub may actually see 750rms which would be great but it gains 2 db over 2ohm and i'm not competing anyway and i should gain 2-3db as it is with bigger box and fu, well see..
2 of them?
Si.
ok i think i gotta decent box design 2.28 cf ad (i subtracted bracing and corner boards as best i could may end up 2.25 or 2.3cf ad but i'm close) 2.75" x13" port (35.75sq in, 15.6sq in per cube) 29.5" long wins calls that 35.5hz, internet port calculator says 35hz (i got that problem earlier figured out) rear port air velocity is at 65 ft per second, should be really good (my 1.5" port has like 85fps now).. just hope he can start on box this weekend..
Ive got a 1250 12” running off a taramps 3k and the other day the coil started buzzing so maybe melted some glue
Got my v1 750's for 130 each ,got 4 of them at a x mas sale.not a single problem after 2+ years. Then got 2 1250's and even happier,just got a 2006 Dakota planning on a blow thru with FU Audio and ampere.
Hope you like them frank u has awesome custmor service even for just a ? Great buy and frank will do you right.
FU Audio ttmff ftw
The 750 will give you better control at higher volumes as you won't be reaching clipping as soon..
Your amp may have failed. A competent shop should be able to diagnose the issue in under 5 minutes either way. You didn't necessarily do...
BOOMINGRANDPA
WOLFRAM FTW
BOOMINGRANDPA
NC
BOOMINGRANDPA
    Jun 1, 2024
    May 31, 2024
