Good headunit for $150
  • 5
mrtonytompson
Hello im looking to upgrade my headunit and dont know what is the best. Does anyone know of a unit with built in crossovers and 3 amp outputs in the back for around $150. Doesnt have to be the best just a good budget headunit. Double or single din. Thanks!!
Sent from my SM-G900P using Tapatalk
what ^ said. amp gain setting info, test tones are at the very bottom...
552
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
mrtonytompson
mrtonytompson
Lansing, MI
Boomin_tahoe
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
