Good headunit for $150
  • 5
mrtonytompson
Hello im looking to upgrade my headunit and dont know what is the best. Does anyone know of a unit with built in crossovers and 3 amp outputs in the back for around $150. Doesnt have to be the best just a good budget headunit. Double or single din. Thanks!!
Sent from my SM-G900P using Tapatalk
417
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
998
mrtonytompson
mrtonytompson
Lansing, MI
Boomin_tahoe
    May 18, 2024
    May 18, 2024
