Head unit keeps blowing fuses
beetlepunk21
Hi everyone, I installed a cheap head unit ( unsure of the brand at the moment ) both in my wife’s car and mine. Everything worked fine for a little while in my 98 4runner and then one day all of a sudden there was just no power to the radio. I pulled the unit out and checked the 15 amp fuse. Blown. As soon as I stuck another one in there it immediately blew as well. I’m a mechanic but I am clueless when it comes to electrical wiring. I tried doing a little bit of research before getting on here. When I spliced the harness together all I did was twist the wires together real good and then covered them with electrical tape. I didn’t use butt connectors or anything. Could this be the problem? Or is it something else? I did the exact same thing in my wife’s 2006 Kia Sorrento and hers has been working fine, no problems. Thank you all so much for your help in advance
Shotty connections could definitely be the issue. Go in and use crimp connectors, especially on the power, ground, and remote wires. Even better would be to go in and solder and heat shrink the wires but it's not the easiest place to get to.
In the future, avoid twisting wires together and electrical taping them. It's the equivalent of putting only water in your coolant system. It may work, but it's not going to last. It's worthwhile to pick up a decent wire stripper, crimper, and some butt connectors off of amazon/ebay/harbor freight etc
Did you change any of the speakers?
I like both wires to connect to each other so use nylon closed end crimps. Butt connectors have a stop in the middle so the wires really don’t touch and relies on the metal inside the connector to transfer the current.
Definitely use something better than tape. Check the harness connection as well there may be loose wires there but check it after you properly splice the harness. If you are not going to cover the connectors you choose make sure you use the ins section on crimper
Or it could be using a cheap head unit , or a faulty head unit. Try the other recommendations first and if they dont work then that would be your answer.
Thank you all so much for your help and input. My apologies for just now replying. I’ve been very busy lately. When i get the time I’ll pull the head unit and splice it correctly 😎
364
678
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
748
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
917
beetlepunk21
beetlepunk21
Oklahoma
beetlepunk21
    Jun 1, 2024
    May 31, 2024
