Head unit size
  • 2
D90
CarAudio.com Newbie
I have a 2011 Chevy Suburban 1500 LTZ. I'm trying to figure out what size head unit (Double Din) would be a good fit. The stock radio is 7 inches across. I wasn't sure if I should get a head unit that is the same size considering the mounting kit might cause the new head unit to not fit, or if I should get a smaller head unit instead. This would be be first car audio set up and I'm tyring to figure out what the best fit would be before I spend any money. Any advice would help. Thanks.
6
276
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
626
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
715
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
870
D90
CarAudio.com Newbie
D90
Chicago
1aespinoza
winkychevelle
    May 24, 2024
