Headlight problem HELP!
  • 2
civic2004
LA
I have a 2000 honda civic exand when i 1st got the car 5 years ago i changed the stock bulbs to some high proformance blue bulbs. Now a couple days ago i noticed that one of them was reallydim so popped the hood and was taking out the bulb and the socket that you plug it into crumbled. Lookslike it was burned pretty bad.What happened? The part for this alone is going to cost me $100!!! because they only sell it in kits and not just by pieces. Kragan,pep boys, auto zone, etc. all tell me it a honda part only and they dont carry it. I dont know what would of caused this to happen.
Go to your Honda dealer, the parts department should have a replacement plug that you can splice in, and sould be fairly inexpensive (around $20 for a pair I think). I have put about a hundred of those in customer's cars, though most were older than yours. I can't say what causes it, but I'm betting it's the additional heat from the aftermarket bulbs. If you strike out at your local dealer, pm me and i'll se about gettin' you hooked up (I'm a Master Tech at a Honda dealer)
The starting ask on diyca.com is $2,500, so no telling what they want in the end, maybe $500k lol. Funny that caraudio.com is no longer valid for...
19
76
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
909
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
658
civic2004
civic2004
LA
bikejunkie223
    May 18, 2024
    May 18, 2024
