Help choosing Amp
I am having trouble deciding what amp direction to go in. The subs i am using are a pair of Sundown x8's. These are the 3 amplifiers i am considering .
Sundown SAE-1500D
CTsounds 1400.1d
Car audio Bargin cab1600.1
What do you guys think?
Is money not a problem? If not I would choose the Sundown. If money is a problem it would be the cab
Sent from my SM-N950U using Tapatalk
I thought the Sundown 1500 was what you had?.. if I had the means I'd go with more power if I could always, seems like whatever I got is never enough eventually... lol... that 2k Sundown looks nice.
Sundown SAE-1500D
CTsounds 1400.1d
you could get that 2k. no ct sounds.. xtr 1500 tested over 2100rms so not bad but not as efficient as others.. before you spend $400 on china sundown amp u could get wolfram 1500 big blank tested $279 or for $249 you could get new soundqubed 2250 bigblank also tested, or the 1250 if you think that's enough power.. https://www.wolframaudio.com/collections/w-series-monoblock-amplifiers/products/w-1500-1 https://soundqubed.com/product/s1-2250/
Shredder,
Yes i had the 1500 and sold it to a buddy for his system. Now i am looking for something different. I think i am leaning towards the soundqubed.
Not at all, amplifiers have gain control to attenuate the output to safe levels.
I've moved this post to installations. Can't work out how to delete it here.
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
If you're shopping in the 10 cents per watt and under department you should probably expect dubious designs and third world build quality from...
17
ROBL3870
ROBL3870
ALBANY NY
ROBL3870
maylar
    Jun 2, 2024
    Jun 1, 2024
