Help Choosing an Amp to power speakers and sub
I like more everything in 1 package, it looks better.
then, the price to buy 4 channels + mono amps it will cost me much more than single 5 channels amp...
Edit:
Does anyone know what are the real RMS ratings of Lanzar RDA755D? Is it really that overrated ?
Also found now an MB Quart OA1100.5 - what you can say about it ? 2 ohms: 150 watts x 4 chan. and 4 ohms: 350 watts x 1 chan... seems good. and lower price ?
Zed audio is very expensive..
My choice is between Precision Power P900.5 and MB Quart OA1100.5...
I want to know which one is better ? Cause many people here recommended precision power, but no mb quart..
Thanks
I can make this simple and tell you to get the P900.5. I have this amp in stock. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Not at all, amplifiers have gain control to attenuate the output to safe levels.
I've moved this post to installations. Can't work out how to delete it here.
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
If you're shopping in the 10 cents per watt and under department you should probably expect dubious designs and third world build quality from...
17
blablablabla
blablablabla
blablablabla
blablablabla
    May 18, 2024
    May 16, 2024
