Help enlosure for american bass hd844
  • 4
Simonusa2010
Ct
Hi maybe you guys can help me
I'm looking to build a perfect box for my American bass hd844, i looked online and couldn't find any information about the speaker I did receive the spec sheet along with the speaker but the parameters are off, because when I input them into winsd how me box like 8cu ft it doesn't show up correctly any input appreciated!
if you gays can do some suggestion i need
box net vol.
Port vol
Tunne
They go to sedan car in the trunk
Amp around 750 watt
Hi maybe you guys can help me I'm looking to build a perfect box for my American bass hd844, i looked online and couldn't find any information about the speaker I did receive the spec sheet along with the speaker but the parameters are off, because when I input them into winsd how me box like 8cu ft it doesn't show up correctly any input appreciated!
box net vol.
Port vol
Tunne
Amp around 750 watt
Build a tline for a single 8 if you have the room. That will give you the most output with the widest bandwidth.
Sent from my SCH-I605 using Tapatalk
I agree with cscstang, t-line would be the way to go. Build this and profit.
If the dimensions don't fit your ride, post your max dimensions and I'll re-design it for you.
Sent from my SM-G925K using Tapatalk
Hmmm this is too big but thank you for suggestion. I need some trunk space
This is largest box what i can fit h12.5 x w25 x d13
My laptop is out of commission so I don't have a way to do a sketchup, but here's a great design for it.
0.85cuft@31.95hz with 15.61sqin port per cube.
21" wide, 12.5" tall, 14" deep.
Port is 11" tall x 1.25 wide x 37.5" long
Box will have 3 port panels and it'll look similar to this.
Sent from my SM-G920T using Tapatalk
Ok im little confusing when i calculating i have different result then yours
12.5h
21w
14d i thing 2x.75 wood yes?
This give me 1.459 cu ft total
1.25x11=13.75 port area
37.5 long
Port displacment are .477
1.459-.477=.982 cu ft
.982 - .06 (speaker displacment) = .922 cu ft net
And when i put this number to the web program to calculate port leng
.85 cu ft 1.25 x 11 port dim with slot port show me 34 inch long
Where i did somthing wrong with my calculation?
129
438
416
Simonusa2010
Simonusa2010
Ct
Simonusa2010
    May 31, 2024
    May 24, 2024
