Help me out fellas!!!
lorideslo
I can get a Memphis c3 sub and a memphis mclass 500 amp. The problem is that sub is rated at 600 watt rms and the amp is pushin out 500watt rms. My question is will that 100 watts be a big difference in under powering the sub?box will be sealed built to specs by the way.
just wondering why a sealed box? with only one sub porting it would help on the output
I'm more sq than spl. I may go ported but leanin more toward sealed.
Thanks and other comments on that sub and amp combo?
it will be fine as long as you dont try to get more from that amp then it can put out and clip it
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
112
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
433
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
406
lorideslo
lorideslo
Hampton, VA
lorideslo
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
