Alpine Install problems
tvro32
I have just installed a new alpine amp MRP-F300 with a pair of Alpine SPR-17C 6 1/2 2 way coaxial speakers. We used the speaker level inputs form the head unit. (BMW 325i 1994). At very low volume the system works great. But when turned up (Normal levels) the amp cuts out for 10 seconds then plays for several seconds before cycling again. The power feeds for the amp are 8 ga less tha 3 feet direct to battery. If I connect a pair for 6X9 8 ohm speakers to the amp (same channel) everything works great. The alpine speakers are listed as 4 ohm. Why would they trip the protection circuit in the amp?
When you say the power feeds are less than 3 ft and direct to the battery, where exactly did you mount your amp?
Pictures please.
Are your grounds sanded down to bare metal? Also do the process of elimination as stated? Do you have a DMM (Digital Multi Meter), if so check you ohm load and voltage at the amp. If not I recommend you get one from lowes or home depot for 20 since your doing self installs
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
466
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
680
I am willing to trade both subs for Kicker 46CK4 wiring kit $81 on Amazon https://www.amazon.com/dp/B07NS9DTWW/?tag=caraudiocom-20 T-Spec v12...
18
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
tvro32
tvro32
fredericksburg, Va
tvro32
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
