Help new kenwood ddx9703s wont turn on
  • 2
Dont see a reset button
Sent from my SM-G955U using Tapatalk
That's weird. I always bench test everything before going to the trouble of taking the interior apart. Check your remote turn on wire for power when the keys in the on position. If you still have good access to the harness, connect both the turn on and constant wires from your HU to the constant on your vehicle. If you have a good ground the stereo will turn on, unless there's something wrong with it.
554
I have a seat Leon 2010 1.6tdi it’s fitted with a seat unit that won’t load sd card internal error so bought the above stereo to upgrade and a...
I would call Kenwood Tech support. Im sure they will try to help you
102
reddzeppelin
reddzeppelin
Texas
JerryLtowIt
    May 31, 2024
    May 24, 2024
