help plzzzz Subz Not Hitting hard
Like from inside the box?
no. un hook one subs power and neg from the terminals in back of box. if the other sub gets louder or hits harder its out of phase.
switch the wires around on that sub and wil be louder and hit harder.
if its out of phase youll realize it tho without needing to really pull the wires. it will probably sound like your subs are blown. check your grounds make sure your amp is not grounded to flimsy metal and or metal that is not sanded down to bare metal. check fuse for corrosion as well.
Either that or at the amp. you need to ensure the positive on each sub goes to a positive on the amp. same with negatives. this will mean that both subwoofers are "in phase" and are moving in the same direction. post a pic of the setup so we can see what you're dealing with. Some cars have loose mirrors or flexible windshields and some don't so shaky mirrors aren't a good indication of how loud something is.
Another easy way to check the phase is to undo the wires at the amp, get a small battery (AA works fine) and touch the positive wire to the positive (nipple) side, then the negative wire to the negative (flat) side. This should force the subwoofer OUT, like out of the enclosure. if both subs move out, they're in phase. also make sure it's not wired to like 8ohms or something on a 1ohm amp. this will reduce the power by a LOT. set gains accordingly as well.
https://www.dropbox.com/s/fjfgpllgv2i03uo/IMAG0213.jpg?dl=0
Well of course the guy at the audio shop is going to say the equipment is good. They will also tell you a pair of kicker comps will throw down 150dbs lol.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
157
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
448
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
424
GrandeGrinda
GrandeGrinda
Casa Grande,AZ
Jeffdachef
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
