Help wiring my subs to 2 ohm load
  • 3
Dankv6
8
Texas
Okay so I have 2 subs a dual 4 ohm sub and a dual 2 ohm sub
How shuld I wire it to get 2 ohms @ the amp
You can't
I wouldn't run different subs with different power anyway
Wire only the dual 4ohm sub in parallel (positive to positive and negative to negative) for 2 ohms at the amp
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
627
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
991
Dankv6
Dankv6
Texas
pickup1
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
