Help with Amp 04 Trailblazer
  • 4
elballz12
I just picked up some Infinity Kappa 60.9cs and some Infinity Kappa 63.9i. I am trying to decide on a 4 channel amp. The 60.9cs are 90 rms per speaker and the 63.9 are 75 rms per speaker. Looked at some hifonics amps but need some help on how much power i will need. New to car audio just wanting to learn some info. I have an 04 Trailblazer with a Pioneer DEH-P8300UB. Its non bose and all stock
I recommend the Sound Stream RUB4.500 Class A/B on e-bay with 2yr warranty, and clean specs.105DB,TDH is 0.015%,75x4-$138.15 shipped from audio-club.GREAT amp with good warranty:D
you cant over power the speakers if you dont push the amp 2 full power, its always betetr to have mor epowe ron tap so you dont have to push the amp to its full extent and in return you have less distortion
That Rubi is a great amp, and would sound nice on the Infinities, and has a good warranty, can also be bridged later on if need be?Id buy that one, if I were in the market, even the Rubi1 1600 class d mono block for the subs too.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thats False:beathors:,.Depends on if you bridge the amp properly to the ohms value it can handle, and is installed properly to retrieve air circulation.An amp will last a long time if you keep them running cool.I have some amps that are over 10 plus yrs old, and still look great, and work as they should.Wires?Power wiring?Depends on how much power you want to achieve, and how long the run of wire.Just that 4ch amp an 8ga kit will be all needed for supply.Yet if you are giong to add a hudge amp of 1500 for subs, and that amp, I go ahead and run at lest a 2ga,or 0ga supply run,to a distrabution fused block,and check out maybe doing the big 3, which there is a thread on here,and I need do myself,and you will have the supply for the bass amp /future supply needed for ?,and you have the block to run from to supply/power amps/fans up to:D,But if you are only going to put just that amp in..8ga supply kit should be plenty,and I run 14ga to my speakers, as some people get by with 16ga.Buying a spool is pretty cheap like 100ft will take care of that truck just fine
I plan on adding a sub in a few weeks. I have heard of doing the big 3 and didn't know if i would need to. I don't know how to run anything but i and having a local shop run it all that does some great work that i have seen. I just know i can but all of the parts cheeper online and save some big $$$
829
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
549
That is correct. I like these as they are twisted pair and the RCA ends are thick and grip quite nicely...
944
elballz12
elballz12
Decatur, AL
elballz12
    May 31, 2024
    May 24, 2024
