Help with box problem
  • 4
Jaxon88
ID
Here is my current setup (I know it's pretty ****, but I got it nearly free and as a teen you can't complain)
Single Sub - Pioneer TSW261D4 10-Inch Champion/DUAL4 OHM/1200W/40 Equalizer
Amp - Sony XM-N502 (Xplod 500 Watt)
Here is the problem, ever since I blew the last subwoofer which was a Lightning audio sub, I have been getting some sound like it's hitting the wood inside the box but this subwoofers height is smaller so it's not hitting the box. I have it wired like this: Subwoofer wiring diagrams Which is how the people in at sound source told me to. When I plug the port on the box it sort of blocks out the hitting sound. The reason why i'm worked up about it now is because I just bought this new amp and I can't even turn the volume up without it sounding like ****. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Any help would be greatly appreciated //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
And also it only sounds terrible at a the higher sounding part of songs.
First of all that amplifier is severely under powered for that woofer. Even if you wire that woofer in parallel you're only getting it down to 85w, and that woofer is rated for 350w RMS. Which is probably why it sounds so bad. Get a better amp and try again.
175 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)? I mean it hits pretty hard. Idk. What would you recommend then?
Could that sub even take 800? Thanks for the recommendation man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If it can't just turn the gain down. It's better to have extra power then not enough
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
738
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
Jaxon88
Jaxon88
ID
Jaxon88
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
