Help with my amplifier
Robert09
I have a 1000 w amp max with 2 channels and it's bridgeable. I installed a 12" German subwoofer with dual voice coils. And ran them in series. My system sounds great until I push it too hard and the amplifier turns off. I have checked for proper voltage at the amp and have a good ground it only happen about 25-30 mins after I start pushing the spkr. And after the amp " cools down" it operates properly
The amps overheating and doing a safety turn off to protect itself from damage. If it's a cheaper amp it most likely has bad heat dissipation. Pretty common and normal occurrence.
You can either learn to live with it; not bump for sustained amounts of time; buy a better amp; move it somewhere more ventilated; build a cooling rack for it with external fans; or some combination. Odds are though if its a cheap amp it's gonna overheat now & then no matter what you do.
we don't know the amp mfr/model or the impedance of the coils. could be a slight short in the wiring that is only a problem at higher voltages. could be you are driving the amp into clipping and it protects itself and the speaker. could easily be thermal.
my best guess is noob decided to use gain as a volume know, and is over driving the **** out of the amp, causing it to overheat after playing for a while.
set your gains accordingly and it should stop overheating, if you need help with the CORRECT way of setting gains, please post model number and if possible full specs of amplifier.
This
---------- Post added at 03:24 PM ---------- Previous post was at 03:23 PM ----------
This
860
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/
932
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
Robert09
Robert09
Jasper,GA.
nateberrier
    Jun 1, 2024
    May 31, 2024
