Help with single sub recommendations for 12" sub for a Rockforsgate Power 800.2 amp
  • 5
dennisspeaks
I have had a Rockford Fosgate Power 800.2 sitting in my garage from my past car, finally going to put into another one of my cars but I no longer have the subs and very little trunk space because it's a convertible so I probably will get a shallow sub, I am looking at recommendations, single or dual voice coil, 2 or 4 ohms. I listen to a variety of music, some country, some R$B.
Thanks
Dennis
Thanks Mastershaker575, for the input, would you go for 4 ohm or 2 and single or dual voice coil for one sub? I am thinking I might beable to squeeze two subs in there using shallow subs.
The Ground Zero Radioactive 12s or even the Hydrogen 30x would be great matches to that amp if you go the single sub route. If you're stuck using shallow subs, look at the Ground Zeri Radioactive Flat 10". If you're interested let me know and we can get on the phone to discuss your needs.
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
Hello, What amps should I use for this: 2xFocal Auditor Sub 12 Slim Focal Expert PS165v1 Can Focal FPX 5.1200 work or is too much?
145
445
dennisspeaks
dennisspeaks
Spokane, WA
Brandon@GZUSA
    Jun 1, 2024
    May 31, 2024
