Help with whine, yes I searched and read a lot
my taurus is a 92 SHO model so its 90 amps for the alt im pretty sure, and if all the ground connections are good with a meter then how will regrinding them help out, and they may be a bandaid, but do those isolators do any harm, like lower signal quality or whatever?
Thanks, a friend wanted to know how big it was //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifThe GLI wont do any harm, but they filter the signal so im shure it would sound different
Prob nothing you can hear though
if you have a 94-96 SHO its 130 amps, and 96+ is a 120 amp unit im not sure about regular tauruses, they dont have the same drivetrain at all so its probly a different size alt, and what was that parthenon thing?
We need more info. It sounds like a definite bad ground, but then you say if you tinker with one of the amps, it stops. Perhaps the ground connection IN THE AMP is bad?
Meh, some solder will solve that pretty quick. If you think it's the amp, disconnect the amp, right the speakers some other way, if you lose the whine, it's the amp.
However, a 90 amp alternator isn't going to get you very far, especially when bi-amping. I worry mine might die on me. I never play music in my car more than 5-10 minutes without the engine running. I killed a Diehard Silver 60 month battery that way. Just remember the big 3.
Parthenon:www.adireaudio.com/Files/Dan/Parthenon //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
His is a 93 i think,its just normal
Big 3 soon to happen !
Ok, problem solved. It wasn't a ground problem...the end plate on the RCA side of the BD amp was pushing on the end of the RCA. All I had to do was put a little more slack in the cord to allow for movement and the whine went away. That's why when I was jiggling the amp it would cut out for awhile and then come back. YaY.
Yep, all the way to the point of if I turn it all the way down, there is complete silence. Im not complaining. Id rather it be something weird and simple, than something difficult where i have to rip out all I have done to fix it.
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
99
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
137
luke32303
luke32303
Jacksonville.FL
brandontw
audiobaun
    May 19, 2024
    May 19, 2024
