hifonics ....re.....or should i go somewhere ealse?
  • 1
timbassett
I'm stuck putting together this new system I sold my old set up and scorred enough cash to buy my new subs and encloshure I have 2 pioneer ts-w3002d4 subs in a atrend sub box its about 1.75 cu.ft per chamber seperated chambers and I have the box wired down to 1 ohm at the amp only problem is im stumped on what amp to buy I ran 2 of these subs at 2 ohms on a power acoustik bamf5500 witch was probably about 800watts rms total from the amp way under powering the subs I was looking at eather the hifoni's brutus 2400 witch is cea rated for 2400 watts rms at 1 ohm at 14.4 volts or a RE xtx5000 witch is not cea rated but rated by re for 2500 watts rms at 1 ohm at 14.4 volts I hear that the re amp puts out only about 1000watts rms I also hear the hifonics is an overated company and ive never used massonix before although i feel better about it being cea rated but im looking to get about 2500watts for between 300-400$ any sugestions ? Thanks for the help
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
The CT's are nice, That Sundown is a a frik'n beast!
7
859
timbassett
timbassett
newington ct
timbassett
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
