SOLD HiFonics Zeus XI Amplifier
318iSPOLKMoMo
For sale is my Hifonics zeus xi amp that I used for nearly 3 months(2 years ago) and its been sitting in my room ever since. I dont have the need for it anymore, and want to get rid of it.
Here are the specs:
MOSFET Operation
All Gen XI Amplifiers utilize full MOSFET operation and use the latest high voltage, high-speed devices. These UHG (Ultra High Grade) MOSFET outputs are of the premium variety and are selected for their low “Gate to Drain Charge” which allows the Hifonics onboard power supply controller to essentially rev the devices to a higher clock speed, making operation more efficient.
In addition, we add two additional MOSFETS to each Gen XI model for higher output.
Ultra Blue High Grade PCB
Our Ultra Blue High Grade PCB is designed from the ground up with a superior ultra-clean layout for minimal signal to noise loss and is designed to flex with any vibration maintaining its molecular structure in extreme heat.
The Biggest Power Supply
The Gen XI Series premium power transformer coil uses the latest in efficient winding techniques to ensure optimal amperage temperature. These large torroids have 40% more copper wiring and turns than our competition. In addition, its state of the art design deflects any unwanted EMF flux, ensuring that your amplifier will remain cool.
General Features:
PWM Power Supply
High Speed Bi-polar Outputs
Stiffly Regulated Power Supply
Fully Adjustable Crossover Networks
Variable 0 to 18 dB Bass Equalization
HP/LP/BP Switch
Variable Subsonic Filter
Diagnostic LEDs
4 Gauge Power Connectors
Class A/B Operation (Except Hercules -- D Class Digital)
Maxi-Fuse
Gold Plated Inputs and Outputs
Balanced Inputs With .4 to 18V Input Sensitivity
Built-in Climate Control Cooling Fan (Boltar, Zeus and Colossus only)
Comprehensive On Board Diagnostics
Bass Level Control
4/2/1 Ohm Stable
Bass Remote Control With Diagnostic LEDs Included
Features
2 x 350 Watts @ 4 Ohms
2 x 550 Watts @ 2 Ohms
2 x 600 Watts @ 1 Ohm
1 x 1100 Watts @ 4 Ohms
1 x 1200 Watts @ 2 Ohms
Price is $200 FIRM. I payed MUCH more for this. If you want a great, handbuilt amp for your subs, this is it!!!
Just came back from vacation. Sorry for the delay guys, the amp is still for sale. To make things easier, lets just say shipping is a flat $30. So im pretty much selling the amp for $230 shipped. I will reply all PMs now since im back from vacation.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
417
318iSPOLKMoMo
318iSPOLKMoMo
Sunland, CA
PsychoTheRapist
