How over rated are your xenon amps?
PG amps are usually solid......When the Xenons first came out, they had quite a few problems.
Ive read that it was primarily the first batch that had trouble........
I didn't see a birth sheet on my Xenon but from what I have read they seem to make more power at 4ohms than at lower impedences. Not huge differnces but 100 watts or so.
Most of the mono-blocks aren't that underrated. The multi channels are the ones with significantly more than rated power.
All 3 of my 200.4's are like 240x4....
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
373
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
518
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
silent1
silent1
Trenton, Ga
faulkton
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
