How should I tune my amp? Level/LPF
DaBurner
I have this sony amp(Click Picture for HUGE VIEW)
http://sonicelectronix.com/item_5027.html#
pushing this L5
http://sonicelectronix.com/item_6505.html
anyway i have the Low Boost all the way up but i dont know what i should have the other settings on, I listen to HipHop/Rap if that makes a difference,
it seems like my sub isnt getting the entire signal because its only responding to real deep bass and not kicking at all
if anyone could tell me how they'd tune this please post
What's your enclosure like? That's probably your culprit. Also, patfiz9 is right you really need to read the gain setting sticky.
What are the specs on your box? Is it a prefabbed enclosure or one you designed/made? Also, now that I think about it, I believe your low boost will boost the stuff around 60 Hz. This isn't really considered low, but maxing this out will give you a very non-linear sound. Try turning your boost off (including the one on your h/u), setting your gains correctly, setting your hp around 65-80Hz and setting your subsonic around 25-30Hz. Try that and see how it sounds...
The CT's are nice, That Sundown is a a frik'n beast!
858
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
715
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
835
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
DaBurner
DaBurner
Long Island, NY
enzowho
    Jun 1, 2024
    May 31, 2024
