In need of help with wiring diagram for subwoofers
That amp is ok with 2 ohms I believe. If each of your subs are single voice coil 4 ohms then wire them in parallel and you'll have two ohms.
That means positive on your amp goes to the positive on each of your subs and the negative to each of the negatives on your sub.
Amp + to sub 1 +and sub 2 +
Amp - to sub 1 - and sub 2 -
VS series. which would be:
Amp +to sub 1 +,
Sub 1 - to sub 2 +,
Sub 2 - to amp -,
Does that help?
If it's 4 ohms per coil just wire the two coils on the speaker as either 2 or 8 ohms by series or parallel wiring, then do the opposite from the amp to both subs. Will give you a 4 ohm total. That's your only option if they are 4 ohms pets coil as that amp I doubt is 1 ohm stable.
If the coils are 2 ohms, you can wire it the same way and end up with a 2 ohm load.
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
Elpolloloco16
Elpolloloco16
Kansas City Kansas
ashren315
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
