Infinite baffle, sealing around the wall?
  • 3
butterMilk
BC
So I have my wall mounted and its a nice tight fit in most spots. The wall is 1.25'' thick and all is good. Theres about a 1/16th to 1/8th gap all around it. I'm trying to figure out a good way to seal it off with out using any expanding foam. And I don't want it to look like a hack job. You guys have any good ideas on how to seal it up?
I was thinking of maybe just using some clear silicone around the edge, but I'm just not sure about it. I know I could just use some "dynamat" but I don't think that would look very good. If you guys got any ideas, or pics of what you have done id love to hear about it!
I wish I had some pics to show what I have goin on, maybe I can borrow a friends camera later. Its basically a wall built about 6'' behind my back seats.
this is similar to how mine is set up. i took some weather-strip and wedged it into the crack, but eventually it blew out(im running 2 15's on 2K infinite baffle). ended up using some tan NON GLOSSY(the non glossy part is key) packing tape around the entire top and sides, the bottom was left with weatherstrip.
Matt
That would definitely look good. But I don't want this to be permanent.
It wouldn't have to be. Either small trim panels glassed to fit the opening or come off the front of the box. Tape the back side if it must be air tight...
I just built a system not long ago in my 2008 C300. I actually cut out the partition behind the arm rest in the rear seat to act like a port. I...
7
Unless something has changed DD designs it's subs to be ported. The Gcon would be a better option for IB.
9
I did see those w that skirt that bridges the gap you refer between speaker lip and door grill and these don’t have that. Just flat behind the...
663
For around 1k rms I’ll double up 1/2” for a 1” thickness all around. If doing a flush sub look I’ll add another .75” baffle depending on how tall...
butterMilk
butterMilk
BC
mlstrass
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
