Installing Kenwood DNX7140 into 03 Eclipse
  • 4
OwChS
Hey guys, i'm working with an 03 Eclipse. Just purchased a Kenwood DNX7140 head-unit and am looking to install it myself. This would be my first time, but I figured what the hell why not save myself the money.
After looking online everywhere for a Double-DIN install-kit for 03 Eclipses with no success, I called up an audio-place and they said that it doesn't require an install kit. A second place said the same thing, but that there might be a small-gap. I don't know how big this gap would be or really what to expect.
Basically, what is recommended here? What are my options as far as getting a custom-kit vs. installing it without a kit? Also, I will def. need a harness right?
Aside from that, is there anything else anyone who has experience installing these can tell me about the wiring being easy or difficult?
-Ow
Like Rich said should not need dash kit just trim ring. As far as a harness you can use a metra 70-7001 for non infinity sound system. If you have the factory Infinity sound system you can either use the metra 70-7003 amp intergration harness. Or just bypass the amp which is under the passenger seat.
The new HU will come with a trim ring? Also, yeah it's the infinity sound system. Also there's a way to wire it so that I can make DVDs while driving. Would you guys know anything about that?
-Ow
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
393
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
OwChS
OwChS
New Jersey
OwChS
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
