Is my rise that bad???
Got a reply from David when I asked him about his setup compared to mine:
"Well, about the flex, I'm not really sure what your doing wrong. Your electrical seems pretty stout, so that shouldn't be the issue. One thing that sticks out is that I was running about 1K more than you, with strapped 2200's. Those Ethos can handle some juice, so give it to them. Also, maybe try raising the tuning to about 34hz and see what happens. I bet you pick up a 1-2 db's, just by doing that. Those Ethos will still dig down to 25-26hz tuned to 34hz. Set you sub at 26hz and call it good. I seriously doubt you will bottom the driver out, not with 5 spider packs on them. They are stiff as hell. Also, my box was built to 1.5c/ft @ 32hz. Other than that, those are the only differences I'm seeing. I know the Ethos like smaller boxes. I've heard 2 cubes is the absolute MAX you want to go with the Ethos before you start losing performance. Maybe that the issue?"
Emphasis added. The answer is, because you can also see DCR at other frequencies and because low impedance is extremely torturous on...
9
My 2 - 15" wedge box is around 5 cubes net with 80 square inches of port. My 4 - 8" wedge box is 3.69 cubes net with 43¾" square inches of port.
7
459
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
9
Eggroll
RingsOfSaturn>your music
Eggroll
Death Metal > Your Music
Eggroll
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
