raytard 10+ year member
So I figured I'd join here and see if anyone has any suggestions of where to go from here, need to do some sort of ill **** in the trunk this winter break
basically its a pioneer deh-p600 (the 690 is in the pics, got swapped out right after i finished everything build wise), hc1400 under the hood, hc600 in trunk, monster 0g front to back with kicker fuse, 200a iraggi alt, kicker/monster rca's, kicker 4g to amps, stinger 12g for speakers, fiberglass pods front and rear (rears with 662c were taken out), fronts hold 2 sets of 660c comps, 2 jbl power 1224 subs in a crappy custom box, gto1400 for subs, 2 gto1004 (one isnt even used...4 channels of 150rms@2ohm and 100@4ohm to be used with more highs, if you have any suggestions)
so heres some build pics of the fiberglass work and semi-finished pics, this is my daily car and i needed to get to work, so i never really got it 100%, just flecktoned the pods and called it a day, im considering just rebuilding them with a ssmb8 and ss 6.5in comp system in each door and wrapping in vinyl, i heard a set recently and loved the clarity and volume, the mids ****** tho, but an ssmb8 should compensate.
took the doors off and made a mold of the bottom part where there was a pocket (it just unscrewed from the back, gave me a nice area to throw some speakers in)
6 rings cut with a jigsaw...not a half bad job if i may say so
supported with i think it was 3/4 in rod and hot glue...not the best idea, should have made it stronger for wrapping
wrapped up and some resin, i didnt really take pics of the rears, i just pulled the carpet off of the bottom of the door, traced it out on mdf, cut it out, mounted a ring, wrap/fleece/glass/bondo/flecktone/mount
test fit
test fit
