Jbl p660c 6 1/2 vs cdt cl-e61neo
  • 3
Hulk311
LA
I used to have CDT 61As in the truck I just sold, I now have a new car and I need shallow mount speakers because I do not want to cut the stock speaker grill (the 61As will not fit). The P660Cs are half the price of the E61NEOs, would the E61NEOs sound twice as good? Any other shallow mount speakers that I should look/listen at? Also, I plan on running them passive.
How much power you running? Also,keep in mind that the jbl's are 2ohm
I don't have an amp yet, but the amps I am looking at, one is 145watts per channel and another is 80watts per channel (RMS).
If shallow mount is what your wanting then I would suggest the cdt's. If the cdt 61-a's will not work then im pretty sure the Jbl's wont either,as far as space. On another note, I personally do not recommend any of cdt's xovers under the 560. Not a fan of the tweeter atteunator(cuts off the tweeter at high volume) And the fact that they are poorly made. And are those ratings at 4 or 2ohms as far as those amps you are eyeing?
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
Hulk311
Hulk311
LA
Ridinhi
