Jeep xj installs post here
  • 1
gabriel ruiz
44
indiana
Simple I would like get ideas as in what's the easiest way to run 4 power wires to the back, and see cargo area installs I have plenty subs so I can do just about anything, what has worked better for you? I'm not a numbers type of person. Thanks
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
410
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
6
817
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
8K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
12
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
gabriel ruiz
gabriel ruiz
indiana
gabriel ruiz
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
