Jeep Xj - Walled 8's
The powerplant has arrived! Got juice?
Started mounting them. I'll be using 6 batteries in the Jeep. These are LP 100ah group 31 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Most power wiring is roughly done. Will try to make it cleaner when everything are in. Amprack in. Try fit both amps. They will be painted and get new stickers since one is upside down.. Also nice to have the right tools for the job!
And about liftkit in the rear.. got weight? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif Hope the leafs don't break!
Thanks! Don't think my XJ is so smart to go offroading now, haha..
I'm a mechanic building fire fighting equipment, and we are using alot of unistrut. And we had the other tools in the workshop. Perfect for my hobby //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks alot! Yes I'm happy how it turned out.. First I wanted to paint the baffles white too, but why not try something different.
Still need to wire everything ++ before videos.. but soon! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks guys!
Quakerroatmeal: Yes I must invert mount them, very tight in the first chamber.. about 3" I think.
Jimmytheheater: If you have tried an diesel XJ you might change opinion, these are extremely slow.. haha, so with my stereo system its not fun to drive. But ofcourse the 4L wants some more fuel..
Woofers and batts are wired, heavy a$$ Jeep!
Have been testing a little now, and I'm impressed and happy how it turned out! This plays loud and nice, and pretty good from about 25hz to 100+
Voltage on idle is around 14,4 - 14,7 when I play, and 15v on 1500+rpm.
First test, peaked at 40hz. Woofers are not break in, wall is not sealed off and nothing is fine adjusted. A lot of roof & door flex etc so here is more potential! But I'm happy with the results, and since its my first real build //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
676
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
989
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
9K
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
Is anyone familiar with, or can help with the Infinity system (with amp) fitted in 2001 Jeep Grand Cherokee? I've installed a Atoto A6 head unit...
StigA
StigA
Norway
Mitch86
Decebal
    Jun 10, 2024
